Viera 37"
Discussion in 'Plasma TVs' started by valeite1955, Jan 28, 2005.
  1. valeite1955
    valeite1955
    Thanks to this forum I have purchased a Viera Plasma with which my wife and I are very happy with the quality of picture etc... which is excellent
    Here comes the but.
    Following the opinions expressed on the forum I have invested in component leads to connect my Cyrus DVD player. (I was already satisfied with RGB through a scart but hey lets go for better). With component leads connected (correctly) I have a completely green picture when the DVD player is set to output component. When set to RGB picture is ok the scart lead is disconnected by the way. Make sense to me this does not. Can anyone help please. Not too concerned as I said RGB through the scart is still very good and for that matter so is RGB through the component leads!!!!!???
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Hi, have you tried switching your viera AV4? repeated pressing of the blue button scrolls through AV4 rgb/s/ comp.
  3. valeite1955
    valeite1955
    Hi happyh
    Thanks for your reply.
    Yes done that Viera indicates it is a component conection, but do not understand why the DVD player needs to be set to output RGB. Set to component the picture is a lovely shade of green. Great if watching the Hulk.
  4. valeite1955
    valeite1955
    Update.
    I have spoken to Cyrus tech. support.
    Their answer " set component in the DVD player to RGB which means Red Green Blue. Ignore the setting YUV this is for scart".
    What a load of .........
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    On my pioneer dvd757ai, you have to set the player to composite or svideo in order for the componenet outputs to work. Setting to rgb will not allow a signal through the componenet outputs.
    I know it might sound daft but, have you made sure your componenet leads are all connected properly? If I had a pund for every time I thought there was a problem but it was just becasuse a lead was not in properly, well, I would have at least 10 pounds :D
  6. valeite1955
    valeite1955
    David
    With the Dvd connected by component (scart disconnected) picture is ok when DVD is set to RGB. When DVD is set to YUV the picture is green.
    Swopping the cables to my panny DVD recorder the settings are as they should be component YUV scart RGB.
    Thanks for your answer.
  7. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,710
    Galactica C.I.C.
    +223
    Sorry mate, Then I am stumped :confused:
  8. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    One last try. I don't know your dvd player.
    Can you actually turn off rgb as well as turn on Comp?
    I know other dvd players regard the two as mutually exclusive.Perhaps rgb is over-riding Comrp.
  9. valeite1955
    valeite1955
    Yes. I am going to consult with the dealer
