Vidikron TGS-XP
Discussion in 'Projectors, Screens & Video Processors' started by Dan5, Feb 25, 2002.
  1. Dan5
    Dan5
    Can anyone tell me where I can get some technical data regarding the Vidikron TGS-XP.
    The main thing I want to know is would I beneift on using a progressive scan DVD player with it or can't it handle it.
    Any other information would be useful.
    If it is of any help here is my setup
    Vidikron TGS-XP CRT Projector
    Denon 2802 AVR
    Da-Lite 67" wide screen
    Mission M72 cinema speaker pakage
    PC with Hollywood Realmajic DVD card
    Regards
    Dan
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,976
    +2,779
    According to the specs it's a Video only device. So no Prog scan capability I'm afraid. Sorry!
    Gordon
  3. Dan5
    Dan5
    It does have RGB and Sync input are these of any use. Could I convert from my PC VGA monitor out to RGB?
    Dan
  4. Gordon @ Convergent AV
    Jul 13, 2000
    13,976
    +2,779
    The PC's VGA output socket will be sticking out a progressive signal of more than 16kHz. So that won't work.
    You could use the RGB sync input to send RGB from Sky/Cable/DVD to it for, hopefully, a susbstantial improvement in picture quality over the composite feed. You'd have to check whether it'll accept the composite signal as sync though. Without reading manual and seeing back of unit it's hard to give definative advide on this one...Sorry again.
    Gordon
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Just to add to what Gordon said
    Standard Video (PAL,NTSC,Secam) only I'm afraid, no progressive, scaller or computor.
    I have the brochure as a PDF if you want it.
    roland@b4projection.co.uk
    Quotes the ideal viesion distance as 3 times screen width!
