Vidikron TGS-301 Help
Discussion in 'Projectors, Screens & Video Processors' started by gardnerp, Oct 14, 2004.
  1. gardnerp
    gardnerp
    I have just got one of these projectors off ebay. Is there anywhere I can get a setup manual for it? Also, I can't find any way to switch the input from the default TV to S-Video. I keep seeing references to a remote online but I didn't get one with it. Can I use the projector without it or am I stuck?
    Thanks.
  2. JMPremier
    JMPremier
    Sep 3, 2004
    145
  3. gardnerp
    gardnerp
    Where abouts is the IR reciever on this projector? I'm trying to find some way of switching source without buying a philips omni but I don't know if my palm m500 is doing something wrong or I'm just pointing it in the wrong place.
  4. gardnerp
    gardnerp
    Anyone? At the moment all I've got is a very expensive paperweight that happens to throw static onto my wall
  5. JMPremier
    JMPremier
    Sep 3, 2004
    145
    There is an installation manual for the 301 here although it is in Italian, but I am sure you will be able to find the location of the ir recieverr from it. Maybe even put the text through one of the translaters online to convert it to English.
    John
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    CRT projectors often have two IR ports - one front and one on the back. The ports are usually covered with a dark red tinted perspex window.
    If possible try standing at least 3 ft from the back of the projector so that the IR beam from your remote has chance to spread wide enough to catch all the back panel.
    Regards
  7. gardnerp
    gardnerp
    I managed to find a source for a replacement (not original vidikron) remote and it works. I can post the source if people are interested. Now I've just got to work out the best way to mount my projector in a rented flat. I don't think the landlord would be too happy if I drilled holes in the roof.
  8. satrianij
    satrianij
    HI!!
    I have a Vidikron TGS 300 and I need a remote control as well can you please share any info where to get it in the US.
  9. DMS1
    DMS1
    You can get remotes, which you will need, and directions from Hi-Rez (USA)888-388-2022. they charge 100 for the remote and 25 for directions but you will be lost without them, I'm lost with them.
    Does anyone out there actually know something about this machine?
