Vider senders
Discussion in 'Satellite TV, Sky TV & FreeSat' started by codswallop, Nov 22, 2003.
  1. codswallop
    codswallop
    I tried to use a wireless video sender a few months back, for fairly obvous reasons, and had one or two problems with it
    1) NTL remote did not work in the second room. it looks like there are a couple of products on the market now that fix that one - DigiSender™ Gold X4 ; One For All SV1720 . Is either of these better than the other?
    2)The picture did not alyays remain 'steady' - is it realistic to expect good quality in the second room - good enough to video for example?
    3)......... and this is why I took it back. Whenever we used the microwave, we had interference. Are the frequencies too close? Will microwaves interfere with the 2 products listed above?
    Comments pls folks?
    :hiya:
  2. neilwillis
    neilwillis
    Hi .
    Sorry I don’t have NTL, but I do use a Digisender/ Videosender for my SKY box.
    1) AEI who makes the Digisender has released a load of new products to cope with cable boxes etc.
    2) It should be good enough to record on - - Might be fixed by the new box you mentioned (DigiSender™ Gold X4 )
    3) How old is your microwave? Does it still have a dial you turn to set the duration of cooking? If you have an old one i.e. non CE marked then it will cause interference.
    Check out the forums at: http://www.aei.info/bb/UltraBoard/UltraBoard.cgi
    Hope this helps,
    Neil
