Videoseven HD Ready
Discussion in 'LCD & LED LCD TVs Forum' started by Iggy21UK, Sep 24, 2005.
Tags:
  1. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    Videoseven LTV 27CH now hd ready
    Must be the CH version though!
    www.videoseven.de
    Specifications
    Panel Type CMO Panel
    Screen Size 27” (68,5 cm)
    Display Area 597 x 336 mm
    Aspect Ratio 16:9
    Brightness typ. 550 cd/m2
    Contrast Ratio typ. 600:1
    Response Time typ. 16 ms
    Display Resolution 1280 x 720 WXGA
    TV System NTSC/PAL/SECAM
    Audio 2x 5 Watt Speakers
    Features HDTV (720p, 1080i), Progressive Scan,
    PIP (Picture-in-Picture) Function, Dual Scart,
    Digital Noise Reduction, HD ready
    Connections Antenna
    VGA (RGB in)
    Cinch (Composite Video in, Audio in/out)
    DVI-D (HDCP, Video in)
    Scart1 (SRGB in, Composite/Video in, TV out)
    Scart2 (SRGB in, Composite/Video in, TV/AV out)
    S-Video
    2x Component YUV (Video in)
    Audio, Subwoofer
    Power Consumption On/Off 180/5 Watt max.
    Power Source AC 100 - 240V
    Power Management VESA DPMS, ENERGY STAR
    Swivel +22.5° / -22.5°
    VESA Mounting VESA 100 x 100 mm
    Certifications & Standards CE, TUV/GS
  2. peahead
    peahead
    Dec 14, 2002
    2,992
    St.helens
    +382
  3. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    32" has less connectors this has two component
  4. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    Been looking at other panels this has more connectors than most?
    i.e two component.
