Videoseven 27" LTV27C 16:9 - Anyone recommend?
Discussion in 'LCD & LED LCD TVs' started by Dillz, Jul 3, 2005.
  1. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    I am looking for an LCD for my bedroom. Have recently got an email from Misco advertising a Videoseven 27" HDTV ready LCD for £528.74 in vat. Has anyone got one of these and can comment on what it's like? Comes with 2 year warranty as well.
    Misco
    Specs;
    Product Description : Videoseven LTV27C 27" LCD TV
    Response Time : 16 ms
    Display Resolution : 1280 x 720 WXGA
    Display area (mm) : 597 x 336 mm
    Panel Size : CMO Panel
    Aspect Ratio : 16:9
    Pixel Pitch (HxV) : 0.4665 mm
    Contrast Ratio typ : 600:1
    Brightness typ : 550 cd/m2
    Viewing Angle H/V : 170°/170°
    Screen Size 27” (68,5 cm)
    Displayable Colours max. 16.7 Mio
    Tv System NTSC/PAL/SECAM
    Teletext 10 pages
    Program Memory 99
  2. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    I got the same e-mail and was thinking of getting one as it spec is 16:9 not like others 15:9 Manual on videoseven website www.videoseven.de
    Appears to be a new model.
    Only one scart socket, dvi optional?
  3. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Just had a look at the datasheets. Strange that the 27" and 32" are 16:9 but the 30" is 15:9. Also a bit disappointing that only the 32" has DVI.
    Where did you see that DVI is optional? Can't seem to see that anywhere.
  4. Iggy21UK
    Iggy21UK
    Jul 3, 2005
    35
    In the user manual on the videoseven website.
    Not sure how you request that option if you buy it?
