videoplus
Discussion in 'Satellite TV, Sky TV & FreeSat' started by areuwithmee, Dec 30, 2004.
  1. areuwithmee
    areuwithmee
    Is it possible to record freeview via videoplus?
  2. Roland Lewis
    Roland Lewis
    I imagine the EPG is the method most would use. Press the 'Guide' button on your remote control, select the programme you want to record, and press the button corresponding to 'Timer Prog'.
    Is there a way to synchronise the listed times with the actual times, e.g. if a programme is delayed? A function like PDC but for Freeview?
  3. Roland Lewis
    Roland Lewis
    When using the EPG, is there a way to synchronise the listed times with the actual times, e.g. if a programme is delayed? A function like PDC but for Freeview?
  4. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,431
    Reading
    +169
    No, not currently.
  5. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,431
    Reading
    +169
    It should be possible. When you input the Video plus code select the required AV input on your VCR / DVD-R instead of the channel shown. Then select the required channel on your FV box. However this method won't change channel on the FV box if you are making several recording on different channels.
  6. Maurice
    Maurice
    Roland, Sorry to appear a bit thick, but I don't own a set top box or DVD recorder at the moment, can you please explain which remote control you are referring to i.e STB or DVD recorder. And is EPG a function of the STB or DVD recorder.
    :lease:
  7. nig28
    nig28
    I think that EPG is the 7 day program guide which some of the newer digiboxes have, I only have whats on now/next.
    Do what Fred said (use the videoplus for the analogue stations only)and then change the channel from say-BBC2 to AV1/AV2
  8. Roland Lewis
    Roland Lewis
    But are Videoplus codes broadcast on Freeview channels? Surely not?
    The controller of the STB. Most STB units can control recorders via SCART using something called Qlink / Smart-Link / somesuch trademark. EPG (= electronic programme guide) is a function of boxes (whether televisions, recorders, or STBs) which have Freeview tuners.
  9. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,431
    Reading
    +169
    Video plus codes are not broadcast anywhere.
  10. Roland Lewis
    Roland Lewis
    Meant PDC codes, oops. They're the small block of rolling black and white lines at the top left of the image, right? Does DVB contain them?
  11. Fred Smith
    Fred Smith
    Apr 23, 2004
    1,431
    Reading
    +169
    PDC is only broadcast on some analogue transmissions.
