Videoplus anomaly
Discussion in 'Digital TV & Video Players & Recorders' started by xtopher, Mar 9, 2003.
Tags:
  1. xtopher
    xtopher
    Given that I entered the time and date correctly into my JVC SVHS 7955 can anyone explain the following:
    On Friday the 7th of Mar programming by Videoplus returned the correct channel, the time and length was incorrect and the date read the 8 of April!
    On Sat I tried again and it returned this time the wrong channel 123&4 (in order but out of sequence) but Chan 5 was correct, but all incorrect times and length and the date now read 9th of April.
    So I re-checked the clock set and found the date to have changed to the 9th of Mar! I corrected this and re-tested Videoplus and bingo everything is now working correctly. I am not a technophobe but am completely mystified.
    I don't like not understanding if you get my meaning! Xtopher
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Your VCR probably pulls time/date updates from teletext signals on a regular basis, if the signal is corrupt for any reason it will set it incorrectly.
    If your video allows you to choose the channel to autoupdate from, choose the one with the best reception otherwise switch off the feature.
    Hope this helps ;)
  3. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,848
    I've always found that Videoplus causes more problems than it solves. With modern VCRs I find it much easier to put in a start and end time rather than try to read a long numeric code without transposing any of the numbers.
    Where I live (North Notts) there is also the problem of whether you receive signals from Yorkshire or Central and what region the newspaper is quoting codes for - because that can totally knacker things up !
  4. Pod Person
    Pod Person
    Because of the above, I personally always set the clock to manual mode rather than auto on my panasonic machines. Don't know if you can do this on JVC machines though.
    Manual means the clock bypasses the need for the teletext signal info.
  5. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Erm, already duly pointed out: :zonked:
  6. xtopher
    xtopher
    thanks rct, John G and Pod for taking the trouble - all suggestions duly noted, xtopher
