Videologic ZXR-750
Discussion in 'Home Cinema Speakers' started by mevetts, Jul 6, 2004.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    Videologic ZXR-750
    As a poor student who is not going to start employment until Sept 2005! Would these speakers suffice in providing basic 5.1 for the next 12 months?
    My aspirations are far higher, but I've got to live within my means! :boring:
    Has anyone experienced these speakers? They seem to get fairly decent reviews (for the money ;) ).
    Any thoughts would be great :lesson: .
    Many thanks,
    Mark.
  2. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Considering their price, they're pretty good.
    I have a ZXR-550 system connected to my PC, and in a small room, they're great. I can happily play games in full suround sound, or pop in a CD and listen to it while working. DVD's sound OK too, although I've only ever tried it out of curiosity. (Not a patch on my Keg Eggs though!)
    They are quite powerful for their size - I have the volume dial turned down low, but they still seem to produce a lot of sound. I haven't really cranked them up, so can't tell you what they do at high volumes (I'll try next time I've got an empty house).
    One thing to watch if you want to connect them to a DVD player is that they only have analog connections, so you would need a DVD player with 6 analog outs. There's no optical or coaxial input.
    [Edit: Just checked the spec of your DVD-S75, and see it does have 6 analog outs, so no worries there]
    Balders.
  3. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks Balders, but I'm now getting all confused!
    I emailed PURE Technical Support and asked if my player was compatible with the ZXR-750 speakers, their reply -
    'Mark,
    The DVD player you have is not compatible with the 750 as it does not provide decoded Audio output in the form of six phono
    connectors.
    Other speaker stands can be use so long as they are provided with universal adapters for small satellite speakers.
    David'
    So I asked if their was any way around this and the response from a different support person was -
    'You will need to purchase a separate digital decoder.'
    From my limited knowledge, I can not see a problem connecting the S75 to the ZXR-750.
    Here is a picture of the ZXR-750 connections -
    http://www.techspot.com/reviews/hardware/videologic_zxr750/subbig.jpg
    Here is a picture of the rear of the S75 -
    http://www.mechamania.net/photo/imege/s75-4.jpg
    What do you think? :confused:
    Thanks,
    Mark
  4. rd350ypvs
    rd350ypvs
    Jun 12, 2004
    52
    +3
    That dvd player looks to have a built in DD decoder, otherwise I can't see the point of having them 5.1 connections on the back
  5. mevetts
    mevetts
    Oct 31, 2003
    439
    It does have both DD and DTS decoders built in.
    I think that connecting the ZXR-750 to the S75 should work fine.......
  6. rd350ypvs
    rd350ypvs
    Jun 12, 2004
    52
    +3
    yes it should
  7. mevetts
    mevetts
    Oct 31, 2003
    439
    There have been some recommendations to go for a cheap 5.1 set from Argos in another thread (see here)
    I was just wondering what my best bet would be. I do not expect much for the money I am spending, but if one was to sound better than the other, then every bit helps!
    These are my choices -
    Videologic ZXR-750
    Acoustic Solutions DS533
    Acoustic Solutions DS833
    Acoustic Solutions DS633
    AS222 - 5.1 Home Theatre Speaker Package
    LG FA-P3000
    The LG is £150, where as all the rest are sub £100!
    I would really appreciate any input from the forum members. I know this is probably a lot less exciting compared to some of the kit you guys get to listen to, but I can not afford anything else just now :( .
    Thanks,
    Mark.
  8. mevetts
    mevetts
    Oct 31, 2003
    439
    I have also found these for around £150 -
    Panasonic SBTP20
    They would match the player!
    Any thoughts?
  9. mevetts
    mevetts
    Oct 31, 2003
    439
    No replies...... :(
    Does anyone have any thoughts........ :lease: ?
    I noticed MurphmanL has a thread titled 'Acoustic Solutions' who seems to be in the same predicament as myself. Suggestions there are that for this sort of cash it may be best to look for clearance items and end of line products?
    Should this be where I head instead?
    Cheers,
    Mark.
