Video up-conversion on AVR-250?
Discussion in 'AV Receivers & Amplifiers' started by Robosapien, Jul 14, 2005.
Tags:
  1. Robosapien
    Robosapien
    I'm shopping for a receiver - probably an AVR-250 or 300. I was wondering if either of these have the video up-conversion feature(S to component). I don't see any mention of it anywhere on Arcam's website.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    Yes they do up conversion from s-video to component.
    To quote from page E-8 in the AVR250 manual which is available for download from the Arcam website:
    "The AVR250 allows for conversion between different video formats. This means that the AVR250 can convert between composite, S-video and component, if required.
    For example, if you are watching a composite input from a VCR, you may view it from the S-video or Component/RGB video outputs of the AVR250. This allows you to use a single (typically high-quality Component/RGB) connection between the AVR250 and your display device."
    Manuals Available Here
