video to dvd recorder can enybody help
Discussion in 'Blu-ray & DVD Players & Recorders' started by andip1967, Dec 14, 2003.
  1. andip1967
    andip1967
    Dec 14, 2003
    24
    Hiya
    New to the forum, just looking for some advice and help please!!
    Just purchased panasonic e50 multi region from richer sounds, very good purchase along with the rest of the home cinema set up, wont bore anyone with what I have, jus bog standard.
    The problem I have is with setting a video recorder to the E50 unit, I am receiving black and white pictures, I wondered if anyone could shed any light on the matter, whether it be black and white or colour.
    Thanks in advance
    By the way its one of the best things i've ever bought.
    Looking forward to the plasma shortly.
  2. bobones
    bobones
    Jan 15, 2002
    453
    +7
    What type of cables/inputs have you used to connect the vcr to the E50? What are your connection settings for the AV inputs on the E50? Are you selecting one of the AV channels on the E50 to view the VCR?
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Whichever input you are using on the recorder,change the setting on'connections' to 'video'.Make sure you change it back to RGB or s-video when reconnecting Sky,or whatever other device you normally have connected there.
  4. andip1967
    andip1967
    Dec 14, 2003
    24
    I am using scart to scart, I have set it to video on the av settings. Will the video have rgb output???
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    VCR's do not have RGB output
  6. malcom
    malcom
    Aug 25, 2001
    526
    +4
    I had this problem too. until I realized that the settings were not matched at both ends. For example "Video" one end and "S" vide the other end will give you black and white picture.
  7. andip1967
    andip1967
    Dec 14, 2003
    24
    THANKS EVERYONE FOR THE REPLIES, HAVE SUSSED IT OUT, AT LAST
  8. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Waht did you pay btw from RS ? I thought they were sold out there
  9. Richard Moore
    Richard Moore
    Sep 14, 2003
    72
    Watford
    This here Panasonic does (on one of the SCARTS).
    Oh and someone asked about the price from RS. The one in Watford wouldn't budge on the 300UKP - which is the same as the usual high street shops.
    I got mine from a shop in Ruislip for 270.
  10. narabdela
    narabdela
    Nov 25, 2002
    270
    Glockamorra
    +5
    No link included and, as stated previously, VCRs do not output RGB. An SVHS recorder will output SVHS from an SVHS tape. though.
  11. andip1967
    andip1967
    Dec 14, 2003
    24
    paid 300 ukp from rs, its multi region, macro disabled, it copies pre recorded stuff from video. Learning all the time.
