Video To Dvd Archiving With Panasonic E55
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jonesman, Aug 11, 2004.
  1. Jonesman
    Jonesman
    Have just purchased the above DVD recored the Panasonic E55.
    I want to archive a load of old videotapes is it just a case of Scart to Scart and pressing Play on Video and Record on DVD Recorder??
    Cheers In advance
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,210
    Argyll
    +2,265
    More or less. Obviously use good quality cables to connect the two. Also I have found I get better results when I hook up by Scart to AV2 as opposed to using AV3 - but that could just be a quirk of my system.
    Ensure you use the Flexible Record option! Fast forward though your video to find the exact length in minutes, goto Flexibe Record and dial in the time! This will ensure the highest possible bitrate is used!
  3. Jonesman
    Jonesman
    Cheers will have a go tonight. :thumbsup:
