Video switching through my amp
Discussion in 'AV Receivers & Amplifiers' started by Docta teef, Aug 11, 2005.
  1. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    After spending months of swaping my component cable between my dvd player and sky box (this via an rgb to component convertor) i decided to buy a couple of short component leads and use the video switching through my amp (not ideal i know) a sony 333es. However i have found that i do not get a signal from the tv/sat input to my projector. If i put the sky box through the dvd input it works fine. Anyone any ideas?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    What signal does the TV/SAT use?
  3. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    Not sure if i understand the question its set to a pal signal form the sky + box
  4. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    As happens tried it again today and it appears to work, not aware what ive done different but thst always appears to be the case
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    you need sky + to be in RGB for the RGB to YUV to work, as you have prob fouind out
  6. Docta teef
    Docta teef
    Nov 21, 2003
    1,262
    Manchester
    +56
    Dont think that was the prob i think i may have just made some stuid mistake. Must say thought watching sky going throught the amp im hard pushed to spot any difference vs direct to the pj. I swapped from a bog standard scart plug to a thor last week and that made a ar bigger change for the better
  7. big_marcelo
    big_marcelo
    I've got most of my stuff routed through my amp (Yamaha 2500) - too much hassle to put everything through the DVDO ... and you loose the on-screen Amp menu, which is great to make quick settings changes, etc...
    I will only route directly the DVD (DVI) and HD Box ... and that is because my amp doesn't do HDMI or DVI swtiching... if it did, I would route it also ....
    If you can't notice a decrease in quality - why not?? so convenient!
    Also, I use reasonably good quality cables (www.cinemacables.com) their Quantum & Dynamix range.... good/noticeable improvement over my previous 'good quality' cables.... and good line filtering for the AMP, so you are minimising any major interference to the signal.....
    Cheers,
    Marcelo
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Actually I meant video signal (as in composite, S-Video, RGB or YUV), but glad to hear you got it sorted already. :)
