Video senders
Discussion in 'Satellite TV, Sky TV & FreeSat' started by everitt1984, Feb 7, 2009.
  1. everitt1984
    everitt1984
    Feb 10, 2008
    397
    +11
    Just had Sky+ installed yesterday and was looking at getting something to send the signal upstairs to the bedroom.
    Whats the best method to do this?
    Had a quick search and saw video senders mentioned. These look good as they're wireless which is a big bonus as could do without running more cables.. But there about £70 for the ones I saw at Maplins which is a tad more than I'd like to pay really.
    Any advice appreciated.
  2. joshua_bond
    joshua_bond
    Jun 25, 2002
    354
    +16
    I can't recomended one but the one i use for sky+ allows viewing in another room but i can't change the sky+ channel. Check before u buy.
  3. nibby
    nibby
    Make sure you get one that is 5.8 Ghz . You might have to pay a little more but it will be worth it . Had the 2.4 Ghz one and was always losing signal . Got the Nikkai video sender kit from maplins last week n not had any probs . You can pick them up on ebay for a little less
  4. everitt1984
    everitt1984
    Feb 10, 2008
    397
    +11
    Which one do you use? Not overly bothered about not changing channel.
    Yeah read about the frequency, also the wireless router uses 2.4 I think so it'd cause some interference. Shall have a look on ebay, cheers.
  5. merlie
    merlie
    Jul 10, 2006
    32
    just ordered the maplins nikkai ? on offer at Maplins at the moment with free delivery and a further £3 off ! ... I've read somewhere in these forums that they can operate the Sky+ functions ... suppose you we can return them to Maplins if they dont work ... so sure you can get the same with ebay.
  6. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
  7. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
    Looking at Maplins website, they sell two 5.8 units, one which has a remote control function, currently discounted to £59.99 which is the HQ model code A13HX. The other one, code A00HR, appears not to have remote control functionality.
  8. The_kUrGaN
    The_kUrGaN
    Nov 29, 2003
    380
    +19
  9. JimmyT
    JimmyT
    Apr 8, 2005
    216
    +9
    I have just bought the HQ model from Maplins. I have Sky HD and its straight forward to setup and all remote control functions work.
