Video Senders & Wireless Networks
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dork knight, Dec 29, 2004.
  1. dork knight
    dork knight
    Nov 25, 2004
    888
    Essex
    +34
    Hi!
    Am thinking of getting a video sender so that we can watch Sky on the tv upstairs but we have just got a Netgear wireless network and I was wondering if they will interfere with each other and, if so, is there anything you can do so that they will both work OK at the same time or should I just forget about having both?
    Thanks!
  2. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    i have a linksys wireless setup and a philips wireless video sender and i dont get that much interference. Bluetooth technology causes a lot of intererence.
  3. markfraser
    markfraser
    Apr 5, 2004
    63
    I have Tranwo video senders and baby monitor (video) and it gets horrible interference from my 3com wireless network. More on the baby monitor to be honest. Its bad enough that we can't really use both at the same time
  4. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    I have an AEI digisender system plus a Belkin wireless router. The router doesn't cause any problems, however, people moving around the house causes interference. We only usually use it at night so it isn't a problem.
  5. Gavin01
    Gavin01
    Feb 3, 2003
    430
    Bromley, Kent
    +10
    I have a maplin digi sender and that suffers badly from my 3com router
  6. markfraser
    markfraser
    Apr 5, 2004
    63
    mine came from from maplin too - probably the same one, and my router is a 3com one. It's a bloody nightmare isn't it?
  7. Gavin01
    Gavin01
    Feb 3, 2003
    430
    Bromley, Kent
    +10
    It certainly is, as the picture i get with my £29.99 maplin is excellant when i switch the router off.
    Ive tryed changing channels as well
  8. Greamec
    Greamec
    Jan 23, 2003
    200
    19
    S.E. England
    I have a philips wireless video sender and a 3com wirless modem router + blutooth, the only problem I get is with the Blutooth. you can change the setting on the philips wireless video sender by flicking a switch and you can change the settings on the router in the software so that you do not get interferance.
    Greame
  9. AndySee
    AndySee
    Aug 25, 2003
    132
    +6
    I have Buffalo Air Station and One for All (All in One whatever..) sender and experience no problems at all. Mind you not really used/tested all of them at same time. Have DECT phones too. all work happily together.
  10. purpleperson
    purpleperson
    I am considering a One for all SV1710 AV sender and have a wireless network. The router is a Draytek Vigor 2600VG.
    Is there a definitive answer about wireless networks and AV senders
    purpleperson
  11. Gavin01
    Gavin01
    Feb 3, 2003
    430
    Bromley, Kent
    +10
    It seems to be pot luck really, some days my system is fine other days i get more interference. Sorry to be of no help
  12. Spooksta
    Spooksta
    Nov 7, 2000
    3,101
    Planet Earth
    +595
    D-Link Network and Philips wireless sender here and no problems. Am after an extra receiver for my Philips if anyone knows where to get one. Google coms up with them but nowhere has them. My philips is the 1400 model and the extra receiver is 1401 i think..
  13. Hopeful
    Hopeful
    I have the Netgear 834G router and the Philips VL1200 and have had no problems with interference. There are 4 channel options on the VL1200 and although there is interference on a couple the other 2 are fine.
    Am also using Bluetooth intermittently and have 5 Dect phones spread round the house but still get excellent picture so no worries about this combination.
  14. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Dect phones don't use 2.4GHz. They use 1.8GHz.
  15. johnnycab
    johnnycab
    Jan 26, 2005
    84
    I have tried the Philips and AEI digisender, with varying degree of success. I have a wireless network with 2-3 PC's. Both digisenders worked fine for one of the rooms. However, in one of the rooms they both had a lot of interference - repositioning the antennae helped a bit.
    Another issue with both digisender's was that, using a microwave renders them completely useless. The picture and signal quality on the AEI is definitely better than the Philips. The Sky remote works better too.
