Video sender Problem Help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by thepostman, Dec 15, 2004.
  1. thepostman
    thepostman
    Help!!....need to send a normal ariel signal (from the wall socket)to a TV set elsewhere in the room as the input is a normal ariel one and i need to convert it to scart to transmit it using a Video sender can you take the ariel signal from the wall feed it into a VCR and output it as Scart signal.......or is it only outputted as a normal ariel signal ??
    Hope this makes sense
    Thx :confused:
  2. Techno
    Techno
    Nov 20, 2003
    312
    You most certainly can mate.
