video sender for sky
Discussion in 'Sky Digital TV Forum' started by DoogyDawg, Nov 2, 2003.
  1. DoogyDawg
    DoogyDawg
    Nov 27, 2002
    182
    Cardiff
    +3
    I have posted in the hardware section, but not many replies, so scuz me for posting hear as well.
    does anyone use a cordless video sender for a sky decoder ?
    I have tried the thompson which was crap, I have read the philips and the digisender from argos are good, I need it to work with the sky remote,
    cheers for any replies, and soz again for double posting.
  2. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    I use the Digisender (the x2 model from Argos) with my Sky+. It works a treat, though the picture does get a bit fuzzy if someone walks in between the two sets.
    Picture and sound are both very good, and the remote works as well (there's a little eye you position in front of the IR receiver on the sky box).
    The x2 part means you can also hook up something else to transmit to your second set (i.e a DVD).
  3. peter-d-w
    peter-d-w
    Mar 8, 2003
    569
    28
    Skipton
    +84
    The digisender from Argos works fine with sky.
  4. DoogyDawg
    DoogyDawg
    Nov 27, 2002
    182
    Cardiff
    +3
    cheers. think it will be the digisender then.
  5. Cambo
    Cambo
    Mar 10, 2002
    123
    N.Ireland U.K.
