video sender and sky (PQ issue)
Discussion in 'Sky Digital TV Forum' started by common, Jun 5, 2003.
  1. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    This may be a dumb question but..I have a phillips wireless video sender to send sky to the TV upstairs.
    My problem is that I have a great picture currently with a £50 QED scart going direct to my Toshiba 36ZD26. To use the video sender I have to connect a scart to the sender and then through to the TV - this has a negative effect on the PQ.
    Would using the second scart output (vcr out ?) on the sky box to a spare scart on the TV work ?
    I would try myself but it is a major hassle to get to the back of the TV.
  2. Geoffc10
    Geoffc10
    yes, use video out on sky box connected to video sender, use tv scart on sky box to tele.
    works on my system anyway
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    Why connect the output back to the TV?
    Use the VCR scart out to the sender (and then onto VCR if you have one) and then leave the scart output on the sender unconnected.
    I have this type of connection from my TiVo (and on to VCR) and it works fine. You will not get a much better picture upstairs useing RGB from the TV output to sender (if sender even sends RGB), but will get improved PQ on your main TV.
    Mark.
  4. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    Thanks chaps
  5. D J Fryer
    D J Fryer
    Jul 14, 2000
    699
    High Wycombe, Bucks
    +10
    thought I would bump this after a search - I have a PQ problem with the same sender BUT I have the following connections and only one RGB scart on my TV
    DVD>Sky+ (VCR Scart) then Sky+ (TV Scart)>TV (RGB Scart)
    If I put the video sender between Sky+ (TV Scart) and TV (RGB Scart) then I only get a composite pic on TV rather than RGB (I am assuming the sender does not pass through RGB or switching as I have to manually select AV1 on the TV)
    Is there any way with this sender that I can get an RGB pic for Sky + and DVD on this TV with sender connected up so that I can get Sky+ upstairs (I know that this has to be composite as that's all it sends!)
    Help much appreciated as the alternative is to go out and buy the OFA VL1720 that states it has RGB passthrough.
  6. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    I have sort of the same problem:
    Sky->Video Sender->JS Tech RGB Converter->TV
    The Video Sender does not parse RGB so to get around it I plugged a Scart Switch between them so I now have the pain of having to flick a switch when going to bed... hardly ideal.
    I've been told you can sort of get around it by using Sky Scart Out to VCR Scart In and then VCR Scart Out to Video Sender Scart In. Haven't tested this though.
  7. D J Fryer
    D J Fryer
    Jul 14, 2000
    699
    High Wycombe, Bucks
    +10
    I think the answer (simple one anyway) is to get the OFA VS 1720 sender - it has RGB pass through - have ordered one today
  8. D J Fryer
    D J Fryer
    Jul 14, 2000
    699
    High Wycombe, Bucks
    +10
    And received it today - will post findings after setting it up!
  9. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    DJ , could you let me know what model it is, price and supplier?
    Dan
  10. D J Fryer
    D J Fryer
    Jul 14, 2000
    699
    High Wycombe, Bucks
    +10
    Dan - the sender is made by One for All and the model is VS1720 - the only two suppliers I could find online were www.blackstar.co.uk (£89.99 inc del) or www.dalepakdirect.com (£86.99 + £5 del) - there was one on e-bay but I missed out (it went for the nearly new cost anyway!. I got mine from Dalepak because I could phone to check stock - ordered yesterday afternoon, received this morning by special delivery along with an extra Sky+ remote - very good service, lets just hope it works!
  11. johndj1
    johndj1
    Oct 9, 2002
    190
    16
    cool, let me know how it goes
  12. D J Fryer
    D J Fryer
    Jul 14, 2000
    699
    High Wycombe, Bucks
    +10
    well intial reports on the VS1720 sender are good - it passes RGB through to main TV and the sound and signal quality on the second TV are very good - even better is the IR sending - no specific placement problems or use of IR extenders to the supplying devices - the front panel obviously has a decent blaster that's not fussy on placement (it is on a AV rack on the shelf above the Sky+ and DVD) - the only down side is that (like the old Philips I had) it does not pass the AV channel switching signal so I have to select this manually using my remote (I may have to do a little macro on the pronto to get over that !)
    All in all definitely worth the £90 or so :smashin:
