Video Processors for Picture in Picture (PIP)
Discussion in 'Projectors, Screens & Video Processors' started by medic3, Aug 29, 2005.
  1. medic3
    medic3
    Hello,
    I'm a new poster, so if this question has been posed before, I apologize.
    I have a home theater setup utilizing a DLP projector. Unfortunately, neither my projector (Sharp DT200) or my Home Theater receiver (Denon 2803), that I'm running through, has the PiP capability.
    Is there a video processor I can use? I need 2 Component Video and at least one S-Video input with a Component Video output (for HDTV).
    Medic3
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    medic3
    Very few if any of the Video Processor manufacturers will include a PnP mode until you get very high up the product/price range where the Processor may have Multi-channel signal processing which makes PnP possible without compromising on image quality.
    Its also a lot trickier to do PnP correctly - especially when you consider you could have one source showing material originated on Video and one showing material originated on film.
    What's the application?
    There may be a relatively low cost way of combining two sources (A and B) on say S-Video to make a third Source (C) that you then input into a Video Processor (along with say YUV from source A and B) - assuming you may want a Video Processor to enhance your image.
    You'd then have a high quality non PnP signal from A and B along with a lower quality PnP option (C) to view when you want the PnP option.
    Best regards
    Joe
  3. medic3
    medic3
    Mr. Fernand,
    Thanks for your reply. I have a home theater system utilizing a DLP projector. I also have my Dell PC hooked in. Unfortunately neither my project nor my HT receiver have the PnP capability.
    I would like to be able to work on the compter while continuing to look at, and listen to, TV.
    Medic3
  4. Chaucer
    Chaucer
    Jul 19, 2004
    38
    11
    Bicester
    +7
  5. medic3
    medic3
    Thanks for the assist Chaucer. $1400+ is a bit much to add this feature but at least I'm getting close.
    Medic3
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    Medic3
    It's not my area but cant you find a Graphics card that includes a TV Tuner and can overlay the TV image onto your PC Desktop!
    Alternatively if your HDTV Tuner is only available as an external source what about a suitable capture card in the PC?
    David at pluggedin.tv is possibly the guy to speak to - they distribute and support the Sweetspot capture card which may be idea for your requirements.
    See http://www.pluggedin.tv/item--SweetSpot-Video-Processor--PITVSS001
    Best regards
    Joe
  7. medic3
    medic3
    Fernand,
    DUH! :eek: I never thought of that. It's an excellent idea. :smashin:
    Thanks.
    Medic3
