Video+plus and Tosh XS32question
Discussion in 'Blu-ray & DVD Players & Recorders' started by welsh alex, Jan 23, 2005.
  1. welsh alex
    welsh alex
    Oct 23, 2003
    50
    got my XS32 yesterday and now just waiting for sky in a few weeks. :thumbsup:
    Tried a video plus recording last night but it started recording about 3 min early and finished 3 min early. i had PDC on.
    why did this happen and how can i prevent it in the future.
    thanks
    alex
  2. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    i've always found PDC spot on - which suggests your clocks not set to right time?
    PDC only effects the built-in tuner & ITV sometimes not supported (not in my area)
    you should be able to check which channels support PDC, via pdc indicator (switches on/off like nicam indicator)
  3. JayCee
    JayCee
    Jan 20, 2004
    20,334
    Lanarkshire
    +1,953
    I don't think the RD-XS32 has a PDC indicator in the display? can someone confirm?
  4. welsh alex
    welsh alex
    Oct 23, 2003
    50
    i cant see it either?
  5. JayCee
    JayCee
    Jan 20, 2004
    20,334
    Lanarkshire
    +1,953
    No, that's because it doesn't have one.
    Personally I wouldn't use PDC..........it's too unreliable and most broadcasters don't use it anyway.
    Auto-clock setting has also been found guilty of failed recordings so personally I would turn it off.
    You'd be better off recording from a digital input (such as Sky or Freeview) for better quality.
    PDC isn't broadcast on Digital transmissions.
  6. BillTheButcher
    BillTheButcher
    Jan 7, 2005
    145
    +7
    Agreed. I thought my Panasonic DMR-E95 was faulty because several recordings completely failed to start. The common factor was that I was trying to use PDC on all of them.
    I haven't used PDC again and the timer has worked perfectly ever since. :)
    (I just set the recorder to come on a couple of minutes early and run for 15-20 minutes after the programme is scheduled to finish.)
  7. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I can.. its on the front panel and seems to flash on and off, going more solid when doing a pdc recording, although I'm not entirely sure what it means...
  8. JayCee
    JayCee
    Jan 20, 2004
    20,334
    Lanarkshire
    +1,953
    Are you sure that's not the Nicam indicator your'e seeing?.
    Where in the display is it?
    According to the "Display" diagram on page 18 of the operation manual it does not have a "PDC" indicator.
    It does have a "PBC" indicator but that's a different thing entirely.
  9. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Its definitly PDC
    It is definitly NOT shown in the manual..I spent ages looking for it a while back to see what exactly it indicated.
    It is just to the left of the record indicator and above the PBC indicator
    It only apears when the recorder is off (and not in eco mode) and set up to do a PDC recording (when it flashes) or during an actual PDC timed recording (when it apears almost solid).
