Video playing problem!
Discussion in 'iPhone Forum' started by tewkes, Feb 4, 2009.
Tags:
  1. tewkes
    tewkes
    Feb 17, 2008
    29
    Hi Guys for some reason my iphone doesn't want to play certain types of video format, i.e won't play videos on BBC iplayer nor will it play certan podcasts downloaded from itunes via iphone! [​IMG]
    [​IMG]
    I'm not sure if its something ive done or something i need to download to make this possible?
    Any help would be greatfully appreciated
    Thanks again
    Tewkes
  2. tewkes
    tewkes
    Feb 17, 2008
    29
    Just a bit to add on, the problem only started to happen after i installed dtunes! uninstalled it but still the same problems?
  3. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    reflash the phone is the best i can suggest (and leave dTunes off) There most likely is a fix, but if there is you will have to go looking through the bowels of the file system.
    just restore it.
    G
  4. tewkes
    tewkes
    Feb 17, 2008
    29
    Hi, thanks for your reply I was thinking of restoring it but I'm on a jailbroken phone using yellowsnow for vodafone and as there is no crack update for 2.2.1 I won't be able to use yellowsnow till the dev team make it possible! Any other ideas?
    Thanks again for advice
    Tewkes
  5. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    you don't have to use the new firmware use an existing 2.2 - look on iclarified i'm sure they have instructions on how to do it (or failing that google it)
    G
  6. dishdoc
    dishdoc
    Apr 16, 2004
    649
    The Toon ! !
    +31
    I'm having the same trouble mate:thumbsdow
  7. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    I've fixed it!!
    go to cydia and remove the safari download plugin - its this that is causing the problem - i'm not sure if dTunes works without the plugin i removed both as it had screwed up my iPlayer too.
    just for info guys - repeat after me "google is your friend" :smashin: it took 5 mins to fix (and most of the that time was the phone doing stuff) i found the solution in under a minute. Just type "dTunes breaks iPlayer" into google - the solution is in the first link. sorry speech over. now go and fix iPlayer.
    G
  8. dishdoc
    dishdoc
    Apr 16, 2004
    649
    The Toon ! !
    +31
    Hey you, I searched google too .... maybe need to be more concise as " certain video files won't play on iphone since dtunes install" didn't get the desired results!!!:rotfl::rotfl::rotfl:
    Thanks anyway, now watching terry pratchet living with alzheimers!!
  9. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    maybe my google kung fu is better than yours :D
  10. tewkes
    tewkes
    Feb 17, 2008
    29
    Fantastic work Gary I just wish I'd read your reply b4 I restored my iPhone :oops:& started from scratch!
    Oh well all back to normal now! thanks again!:smashin:
    Tewkes
  11. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    yeah but at least you've got rid of a load of crap and cleaned the file system up :smashin: (although now you do have a load of reinstalling to do)
