video over short run of cat5 can it work??
Discussion in 'Home Cinema Building DIY' started by disastermaster, Jun 21, 2004.
  1. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Is it possible to connect a video (scart) to a television(scart) using cat5 cable, without any amplifiers etc?
    The cat5 is already installed and I thought I could make use of it. The run is about 7 metres long. Iam not too concerned about the quality as it is just a way of letting my son watch cartoons on the tv. Can it do any damage to the video or the Tv? Any advice on what would be the best way of wiring the cable would be appreciated.
    Cheers TIA Disastermaster
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
  3. doink
    doink
    If you really aren't bothered about quality you can just pair up multiples and send a composite image down them, it'll work... you just wouldn't want to watch it yourself for too long!!
  4. disastermaster
    disastermaster
    Dec 10, 2002
    48
    So it is possible! So I use one pair of wires for comp signal one for ground one for sound left and one for sound right? So it wont damage either the tv or video player? What sort of picture should I get over about 7 meters?
    Thanks Disastermaster
  5. doink
    doink
    Just replied to this but it seems my post vanished into the mire!
    I did the same thing using a mono signal and composite video for a camera install a while back (using existing network install)
    The picture will be watchable but not up to the same standard us AVphiles are used to.
  6. doink
    doink
    Oh, and there will be no damage to your equipment from doing this.
    Just make sure you are carefull wiring up to the fragile solid core cat5
  7. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Thanks for the Info!
    Cheers disastermaster.
  8. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Just to clarify is it right that you use a common ground for the comp and the audio?
    Cheers Disastermaster.
  9. doink
    doink
    NO!!
    Seperate definitely.
  10. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Cheers M8 that's clear now.
    Disastermaster
