Video Out Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Craig_Nike, Jan 26, 2002.
  1. Craig_Nike
    Craig_Nike
    My DVD player has Component, 2 x S-Video & 2 Composite video outs.
    Now normally you would just have 1 of them connected up to your TV ?
    What happens if you connect up all of them to different TV's ?
    Are all the connections receivnig video all the time ro do they just turn on when there is a connection there ?
    If you have all 5 connected up does it degrade the quality since the DVD player has to send more power out ?
    Please help.
  2. Guest
    with my dvd player, if you use component, it disables rgb and svideo output, so you only get composite.
    and the 2 svideo sockets cannot be used simultaneously.
    i suspect the 2 composites are fed continuously.
    you shld prob check your manual to determine if all are available simultaneously. at least experiment by connecting your tv to each of them in turn.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
    With my Pioneer 737, I routinely have
    Component
    1 x S-Video
    1 x Composite video
    all connected up together.
    For reasons it would be boring to explain, the Component goes to the projector directly; S-video goes via the AV amp to a VCR and to the projector, and composite goes via the AV amp to the TV.
    All these outputs have a signal on them at all times.
  4. Craig_Nike
    Craig_Nike
    I'm aware that all 5 will run at the same time, what I'm really asking is will the quality degrade any if all are connected vs just having the component hooked up directly to the TV ?
    I cant see a big difference, but that is a lot of video sources it is having to throw out, I cant see how there wouldn't be loses ?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Since different outputs are wired independently (and hence buffered seperately) I would not expect any visible losses.
