Video out doesnt work on the Classic
Discussion in 'Headphones, Earphones & Portable Music' started by gerbilly, Sep 12, 2007.
  1. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    What is the point of this they are making having any form of dock pointless if you are only able to view your video's on the pod then you have disabled so much of its functionality.
  2. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
  3. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    Video out *does* work on the classic - just not through the headphone jack any more. If you have the old universal dock, you can still get composite video out of the line out socket on that and s-video out of the s-vid socket. Tried both last night with my classic, and they work fine.
  4. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    A review by ars technica says video out is crippled and if you connect to a dock like the onkyo ds a2 it wont work.
    Is this wrong?
  5. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    Video out only works on an Apple dock - there is a chip inside Apple docks that identifies itself to the iPod and tells it how to configure the output lines. If a dock doesn't have this chip, video out won't work. I'm guessing this is because the new iPod support component video output as well as composite and s-video, and the dock connector has a finite number of pins. I'd guess there is some form of negotiation between the dock and the iPod to tell it that it is connected to either an s-video or a component compatible peripheral, and that the iPod then assigns signals to pins accordingly.
  6. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    So my onkyo dock is not usable then?
    The problem with apples dock is you cant control everything like you can with the onkyo remote. Will I be able to connect the apple dock to an amp which can upgrade a video signal?
