Video input on Amplifier
Discussion in 'AV Receivers & Amplifiers' started by bunbenho, Feb 6, 2002.
  1. bunbenho
    bunbenho
    Sorry, it may be a simple question to ask!?
    Why there are composite inputs and S video inputs on amplifier, is that there for some kind of purpose? I thought Amp/Rec is mainly for the sound??
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    An AV Amplifier is called an Audio Video/Visual (whichever side of the fence you sit on) for a reason. If were simply the sound side of things, it'd just be an A Amplifier.
    Personally I believe the video should be taken away from the amp, and all the money spent on audio capabilities. It's just a waste of space really, and tempts too many people to route their vid through it, possibly reducing both the signal and the amp's overall performance. However, I wouldn't mind seeing a few more component in's and out's.
  3. laurel
    laurel
    If amp included video format conversion on the inputs/outputs this might be useful.
    Are there any amps with this facility?
    Laurel
  4. graham.myers
    graham.myers
    I have several s-video components and only one s-video input on the projector. I use my amp as a connection box. My component DVD goes straight to the pj though
  5. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I've never bothered to connect anything up through the amp before but my New Marantz has OSD set up only.
    It is a shame that amps don't have RGB connectors as that would solve a lot of problems with people having only one RGB scart on the TV and loads of RGB kit.
  6. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    The new Denon 5803/A1SR will have this. Comes at a price though. Probably 3 grand plus!!
  7. laurel
    laurel
    3 grand...
    infierno sangriento!
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I do use the video switching facilities (S-Video) and find it rather usefull.
    You probably mean SCART? Worst connector there is; but I think you are aware that
    you can use component connectors to switch RGB!?
  9. DaleL
    DaleL
    With ref. to my Yamaha DSP AX 620 the video input needs to be used so that you can use the amps on screen display for setting up.You can use the amps front display but its easier on the tv.
    I`ve not noticed any differnce in the picture quality either.:)
  10. Doubledoom
    Doubledoom
    If the audio can be routed via the tv and then to the amp, this can save money on the cables, as well as giving you the best signal quality (RGB or component).
  11. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Video input is not needed for this, only the output to the TV/display. And for an OSD, all you need is one of the cheap'o composite vid leads you get free with, well... everything.
  12. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Except when you have a pain in the bum TV that only outputs audio from the tuner, even when watching a DVD or Cable TV through scart... for some reason known only to Satan himself and his silly TV minions.
  13. DaleL
    DaleL
    I stand corrected :)
