Video "freezes" when copying to camcorder
Kainey
When copying edited video back to my JVC DV camcorder, the output periodically "freezes" for a second or so, then continues normally. This freezing shows up on the tape. It co-incides with a burst of HDD activity, and happens almost exactly every 2 minutes of edited file. When I watch the edited files on the PC before attempting transfer, they run seamlessly.
I'm using Video Studio 7.01 with a firewire connection, copying from a 32GB partition on a 80GB HDD. The partition is used exclusively for video editing, and is always defragged before attempting to copy to the camcorder. It's a Maxtor 7200rpm UDMA133 drive, and I have a 1.8GHz processor and 512MB memory. I would have thought the hardware was easily up to the job.
I'm tearing my hair out with this, any ideas?
Cheers,
Clive K
B
Brian110507
Sounds a bit like a virtual memory problem, try increasing the size a bit and see if that helps.
Kainey
Bingo! It turned out that the video partition had no virtual memory configured at all. I set the default and hey presto - the problem was fixed. Many, many thanks.
Clive K.
klr10
Yep, Thanks Beejaycee - you've solved a problem I've had for ages (not as severe - but still annoying)
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
