New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
I have a 1080p plasma screen connected by HDMI to a DVD player.I have the choice of setting 1080i or 720p on the video format section of the DVD set up menu,which should I use? Thank you in advance for your help.
you should try each of the settings and see what looks best. it depends on if the panel does a better job of upscaling or the dvd player. if it's an expensive panel, but a cheap player, the panel might do a better job
