Video Essentials DVD etc.
Discussion in 'General TV Discussions Forum' started by Cinders, Oct 24, 2001.
  1. Cinders
    Cinders
    Can anyone recommend this or a similar dvd for setting up your tv / system? And where can I get it from?...
    Thanks. Matt.
  2. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    18,629
    Inbetween Upgrades !
    +6,996
    Matt,
    I have this very disc. It,s content for set up is quite comprehensive and yes i would definitely recomend it. Although i only use it for video purposes as i use other means for audio set up. I believe you can rent the disc for a week or so from discemporium. com
    I,ll answer any questions on the disc itself.
    Hope this helps
    Kev
  3. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
  4. Grubert
    Grubert
    Jun 15, 2001
    601
    28
    +72
    Also there's a new version in the works, called Digital Video Essentials. It has been said that it will feature PAL test screens.
  5. bob007
    bob007
    On the R1 dvd Castaway there is the THX Optimode, very basic but it covers brightness, contrast and colour plus it gives you a good idea on your sets geometry etc. There is also an audio section, channel level and crossover test. It`s not on R2 so you will have to buy the disc. :cool:
