Video Decoder Error
Discussion in 'Desktop & Laptop Computers Forum' started by Synchro, Mar 10, 2005.
  1. Synchro
    Synchro
    Nov 14, 2004
    5,581
    Chester
    +1,317
    Using NVIDIA Geforce Ti 4600
    HAUPPAUGE NOVA-T DIGITAL WITH FM STEREO TUNER
    Using MS Media Centre.
    What can the probelm be?
    "The video decider has either malfunctioned or is not installed. Please restart Media Centre and/or the computer".
  2. Dave_M
    Dave_M
    Jan 31, 2005
    54
    Harrow
    There's a discussion about this going on in the 'How good is the ELonex Artisan' thread ...
  3. Synchro
    Synchro
    Nov 14, 2004
    5,581
    Chester
    +1,317
    Most of what I saw, was of little relevence. Thanks anyway.
  4. Rambles
    Rambles
    Jul 14, 2004
    7,654
    UK
    +888
    What codecs do you have installed on the PC? What type of movie are you trying to play?
  5. Synchro
    Synchro
    Nov 14, 2004
    5,581
    Chester
    +1,317
    I am trying to watch free to view TV.
    I have not installed any extra codecs?
    How would I find out what codecs i have installed?
  6. Rambles
    Rambles
    Jul 14, 2004
    7,654
    UK
    +888
    If you bought this from a retailer, I guess they should provide you with support? If you built it yourself, then have you checked that the graphics card and tv card are MCE compatible, and have you the latest drivers installed and got all the windows updates.
    Has it ever worked?
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,238
    Manchester
    +747
    In Device Manager, "look at properties of sound,video and game controllers".
    This may not list all installed codecs.
    A free utility called GSpot gives much more detail when you download , install and run it.
    You can search for this in Google (with a search string like "Gspot video codecs").
    Chris Muriel , normally Manchester - currently working in Poznan, Poland.
  8. Synchro
    Synchro
    Nov 14, 2004
    5,581
    Chester
    +1,317
    Home bulid.
    Not first PC, but first Media PC.
    Anyone else using these cards with MCME 2005?
  9. Rambles
    Rambles
    Jul 14, 2004
    7,654
    UK
    +888
    Ok, well here is a link to supported hardware http://www.microsoft.com/windowsxp/mediacenter/partners/dfw/partnerlisting.mspx
    It doesn't look like your graphics card is supported, I am running mine with a Geforce FX5200 which is inexpensive, fanless (silent) and works well...
    Getting all the latest MCE approved drivers for your hardware is important, and you will need an approved DVD codec, not sure if you need that for TV viewing or not, but you will have to put one on there anyway. I use PowerDVD6, but there are others that are good, Nvidia / Theatertek is popular.
    Also try www.xpmce.com and www.thegreenbutton.com for more help and info.
    Good luck
