Video Conversion and switching
Discussion in 'Projectors, Screens & Video Processors' started by gwc, Sep 9, 2004.
  1. gwc
    gwc
    Oct 21, 2003
    499
    Wokingham, Berkshire
    +7
    I am currently planning out a Home Cinema and I am current looking at the cabling side.
    Do Scalers/processors perform a conversion switching function? So that you only need to run one cable (say DVI) to a Projector.
    Or do you need to running a cable for each source component?
    Gwc
  2. Dan Smiffy
    Dan Smiffy
    Yes you would only need to run one cable from the scaler to your display - as well as scale / covert or whatever it'll also switch. I run a single lead from my scaler to the plasma. Now all I gotta do is bury that cable in the wall... ;)
    dan.
  3. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Hi Dan,
    Thanks for the reply. Do you have an recommendations as I have no experience of scalers/processors and need a nudge in the right direction.
    gwc
  4. Dan Smiffy
    Dan Smiffy
    Hiya, I bought an iScan HD to sit between my sources and my screen and while I am very (*very*) happy with it I cannot really advise "buy X not Y" because I have no experience of any others in operation! In the same way that all "what plasma should I buy?" threads turn into an "I bought a X and I love it" vs "I bought a Y" posting competition, I'll start by saying the iScan made my NTL Digital box's pictures watchable on my 50 incher, because when sent straight to the screen I could've cried! And on top of that it is (relatively) cheap. Next month Gordon's coming round to ISF me, when that's done the source -> scaler -> screen will arguably look as good as it is ever gonna look so I'll be in a better position to judge just how fab it all is. I'll get back to you!
    Dan.
  5. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Thanks for that, Dan.
    Is the ISF calibration expensive?
    Gary
  6. Dan Smiffy
    Dan Smiffy
    When looked at in terms of the number of DVDs or pints of beer I could buy instead - yes it is, very! But since I've already spent nigh-on six grand on a plasma + scaler + DVD player + my monthly sub to NTL, I consider it worth the cost to make sure I'm definitely getting the max out of the money I've already spent. I ummed and ahhed for a long while about getting it done - if you do a search for "ISF plasma" you'll find all the same posts I did which eventually convinced me to go for it!
    dan.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,759
    The Borders
    +3,287
    gwc
    Most Video Processors do act as video switchers and will accept a range of varied Input signals and bring them all together as one output signal.
    If your planning a Home Theatre the 'big' question is if your sticking to a single display device (plasma) or possibly two display devices (plasma + projector).
    Many Video Processors can potentially have Two output memories set up to enable you to have different settings to suit multiple displays - though mostly the Video Processors only have a single output so you may need to add a Digital (DVI or HDMI) or Analogue (RGBHV or YUV) Video distribution amp 'down stream' of the Video Processor.
    Its also not unheard of to have a third display device to 'preview' your video sources if you have the kit in a separate room or a cupboard - where you cant actually see you main display; a small LCD PC monitor is often used.
    You also need to plan carefully if you want to be able to record any video sources to DVD, VCR or PC - your not likely to find a recorder that works with the scaled output from the Video Processor so you have to send the 'un processed' source signal to a Recorder plus the Video Processor.
    Any questions please shout.
    Joe
  8. gwc
    gwc
    Oct 21, 2003
    499
    +7
    Hi Joe,
    I will be sticking to a single display device, a projector (not decided which one yet).
    I think mine will be a fairly simple set-up:
    DVD
    SkyPlus
    X box
    Playstation2
    all connected to the scaler.
    Have you any recommendations to get me started?
    Gary
