irascian
Apologies if this question is a bit naive!
I have a Pioneer PD502 plasma and cannot afford to replace it (with a full 1080p jobbie and larger screen) for a year or so yet. I use it in conjunction with a Yamaha DSP-A1 which is great for audio connectivity but doesn't attempt to do video connectivity.
At the moment I'm struggling to connect everything I want up.
The PD502 has a single set of component video leads which are connected to a Digital Freeview PVR device.
I have an XBox 360 connected using PC input and am happy with the results (could detect no difference between using this and swapping the component video leads).
My problem is I have several other devices I need to connect but no way of doing so:
Toshiba XE1 - would like to use HDMI 1.3 cable if possible
Sony PS3 (not bought yet because of connetivity problems, but if there is an easy solution will purchase and would prefer HDMI connectivity)
DVD Player (currently being repaired but my only Region 1 player. High-end, usually connected via the component video cable that the PVR is currently using).
I guess I'm looking for some sort of video version of what the Yamaha amp does for sound, but which allows me to connect up HDMI devices and other component video and has a component video out cable (the best quality I can get with the Pioneer PD-502).
Is there such a device or am I screwed until I can afford a TV with HDMI inputs?
Thanks, in advance, for any advice/suggestions.
