Video Connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by sy278, May 4, 2005.
  1. sy278
    sy278
    Jul 4, 2004
    510
    28
    Glasgow
    +40
    Which method of video connection is best?
    RGB or S-Video?
    Which DVD to AMP audio connection is better, Optical or Coaxial?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    RGB generally seen as better,some may disagree though.
  3. sy278
    sy278
    Jul 4, 2004
    510
    28
    Glasgow
    +40
    any other opinions?
  4. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    The hierachy generally goes;
    1.)Composite video
    2.)S-Video
    3.)RGsB
    4.)Component video
    5.)RGBS
    6.)RGBHV
    Theres not a lot between 3/4/5 and has more to do with the connection method. unfortunately RGB in its various forms tends to be flawed over here due to the rather dodgy SCART connection method :) Component tends to be best for DVD as thats the system used for encoding the discs :smashin:
  5. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Oh sorry, as for audio SPDIF coaxial is normally considered best :smashin:
