T
Tracey
Is it correct that if I decided to get a plasma that only has one input, that I would connect the Sky box and DVD recorder to the AV8 via composite connections, as this way the video switching would be handled by the AV8, or would I be better off getting an extra connection device so that the sky box and Dvd recorder are connected by RGB scart into the plasma?
I'm hoping to lay all my cabling under the floor this weekend (finally) and as my AV8 will be situated on the other side of the room to my tv (or eventually my plasma), I need to know what cables to run to make sure I have everything covered. I've got the audio sorted and I've got a composite cable but I didn't realise that with a plasma I should also run video cables as the AV8 can process these. Can anyone offer any advice as to how I would achieve the best picture through Sky. I'm not worried about automatic widescreen switching, I don't mind doing that manually.
