video connection to an AX5 amp
Discussion in 'Plasma TVs' started by mikeham, Dec 24, 2004.
  1. mikeham
    mikeham
    I have just received delivery of my ax5 amp, 868 dvd and 435xde plasma.
    I have connected hdmi from the dvd to the media box, and i-link from the dvd to the amp.
    At present I have std sky and have sky+ on order. At present i have the red and yellow from sky to the amp.
    The book says to include video connections to the Amp.
    Why?
    Also any ideas on colour setting, mine seem far too rich out of the box.
  2. mikeham
    mikeham
    sorry forgot to ask - how do you check the hours useage
  3. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,019
    Southampton
    +236
    With regards the reasoning behind hooking up the amp to the media box - one of them being that it helps with the initial settings on the amp,as they are displayed in a user friendly-ish way on your screen.
    With regards the engineers screen on your panel/media box - try the one that applied to the 434/504,namely -
    On the remote press the orange standby button.Press the channel info button and wait 3-4 seconds.Press left-up-left-right and then the orange button that puts the panel into standby. If it's the same as it's predecessors,it should display the hidden engineers service menu
    HTH.
    Merry Xmas
    Jerry
