video capture
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by gino555, Apr 24, 2005.
  1. gino555
    gino555
    Mar 27, 2005
    411
    +7
    can any one recommend some free software so i can transfer my video direct from my sony handycam dcr-pc106e mini dv camcorder to my pc as the software package supplied does not allow this.
    gino555
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
  3. gino555
    gino555
    Mar 27, 2005
    411
    +7
    thanks i will give it a go
  4. koreajohn
    koreajohn
    Hello,
    I have Windows 2000 and when I tried to capture the footage from Sony DCR-PC109 DV camera using Windows Movie maker, I could capture only using USB cable and not by IEEE1394 cable. Does any one has any idea why I can't capture using IEEE1394. Is the problem with Windows 2000 OS.
    Thanks,
    John
  5. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    The Garden of England
    +32
    Hmmm - it's muy understanding that Windows Movie Maker only comes / works with XP....
    But take a look here it's a GREAT site for all things Movie Maker..... :thumbsup:
  6. koreajohn
    koreajohn
    Helllo,
    I captured the footage using Windows Movie maker and the format is .AVI. Now I would lile to make a VCD out of that. Could some one can give suggestions on making VCD with better quality.I am using Adobe to write.
    Thanks,
    John
  7. fastpuma
    fastpuma
    Apr 3, 2005
    45
    gino, hi! i've just got my sony dcr pc106e camcorder as well, but im having problems connecting to the laptop, how did u use the program? i mean when i connected using the usb cable i wasnt able to use the usb streaming in the picture package cd rom, i had all the usb switched on but it wasnt letting me transfer it over.there is a prgram call vcd maker with it, did you have any luck with that?. i posted a query a few days ago and mark says im better off using a firewire cable to transfer the video over to the laptop. is that what you are using? well i found out theres a program call windows movie maker, maybe you should give that a try. let us know how you got on.
