Video Capture Software
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by aeaston, Jul 12, 2003.
  1. aeaston
    aeaston
    Jul 12, 2003
    3
    Swansea, Wales
    Just bought a Dazzle DVC80 for the PC. Am basically capturing video off one PC via S-Video and capturing on another PC. The software that comes with the device is called MovieStar (I think made by Dazzle themselves). It seems pretty basic and can't seem to apply codecs to the video during capture. As a result the AVI files it captures are huge and have to be run through a codec afterwards.
    Anybody know of any other software products usable with this device that will allow me to apply a codec on the fly during capture (preferably DivX 5.x)?
    Andrew
  2. KO.NET
    KO.NET
    Yeah, check out PowerDirector Pro by Cyberlink (same company which makes PowerDVD). You can capture in loads of formats on the fly, such as MPEG 1 (VCD), MPEG 2 (DVD), Windows Media Video and now even DivX 5.05 ! This program also has a host of other great features, i use this quite often and highly recommend it . Here go check it out :
    http://www.gocyberlink.com/english/products/product_main.jsp?ProdId=45
