Video capture software
Discussion in 'Computer Software & Operating Systems' started by J273, Sep 16, 2007.
  1. J273
    J273
    Aug 8, 2006
    1,521
    Swadlincote
    +31
    Im trying to capture videos from my sky+ box using the s-video port.
    Ive got it setup fine s-video from the box to my NOVA TV S-plus (s-video) and line out to line in on my sound card.
    whats the best software to capture the video?...Ive tried movie maker but i need it to be captured in .AVI format.
    Can anyone recommend me some software to capture the video?
  2. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Do you want to capture uncompressed AVI?, if so they try dscaler..
    www.dscaler.org
    download version 4..
    set up your card and get to grips with it
    capture at fll fram uncompressed avi
    will need 30mb/s HD transfer rate
    video will be interlaced, so once captured load it into Winodws Media Encoder, selects your compression settings and the deinterlace option then encode
    Alternatively try virtual dub and the Divx decoder for capturing...
  3. J273
    J273
    Aug 8, 2006
    1,521
    Swadlincote
    +31
    Thanks ill try dscaler.....I tried virtualdub it records the videos fine but when i play them back for some reason they playback in slow motion as though the pc cant keep up:confused:
  4. J273
    J273
    Aug 8, 2006
    1,521
    Swadlincote
    +31
    Yeah dscaler seems to work a treat....what pixel width is best to record in?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,549
    Rainham Essex
    +2,523
    Movie Maker will capture as .AVI, but is set by default to .WMV
    Full help on using Movie Maker can be found Here and details on setting the capture to .AVI Here.
    Mark.
