Video Capture Problems
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by percy961, Aug 20, 2004.
  1. percy961
    percy961
    I am having problems with capturing video from my Camcorder, my video editoring software keeps telling me "No Valid Video capture devices were detected" .....Can anyone tell me how I can check that I have a Valid Video capture devices on my PC, My Graphics card is a 265MB Geoforce FFX5700.. My Video Camcorder is A digital, JVC GR23
    or any other help on this matter, I'd be Grateful...Thanks :lease:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    Ok to capture from a digital cam you need to connect it to the PC via firewire as USB is not good enough. Or perhaps analogue connections if you have an analogue capture device, but you will loose a lot of the quality going this route.
    If connected as above then you need to start everything in the following order:
    connect cam to PC via firewire
    power on cam (in VCR mode)
    boot PC
    start the capture software
    If the PC is already running then you wont need to reboot unless you are still having problems. A clean reboot is always a good idea though before starting any video editing.
    Mark.
  3. percy961
    percy961
    Thanks for your help and please excuse my lack of technical knowlegede, on my camcorder I have only USB or DV connections, so how does Firewire fit into that scenerio ?
  4. Brian110507
    Brian110507
    DV is Firewire - also known as i-link and IEEE1394
    You will need a firewire cable with a 4 pin connector on one end (for the camera) and a 6 pin on the other (for your PC) - this is a standard lead readily available in all good camcorder shops.
    If you do not have a firewire card in your computer they can be bought quite cheap (£20-£25) usually complete with a cable and take a matter of minutes to install
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    £20 - £25 for a firewire (DV) card :eek:
    how about:
    www.ebuyer.co.uk
    Quickfind code: 60573
    £11.74 inc VAT
    two 6 pin sockets and one 4 pin.
    6-4 pin cable included.
    Mark.
  6. percy961
    percy961
    To MarkE19 and Beejaycee, Thanks for all your help...Im on the right track now.
