Video Capture Audio Problem
Hitachi163
I have a version of Arcsoft Showbiz 3.5.15.68 to use as video capture for transfer of my old VHS tapes to digital format.
I have noticed the audio lags as the recording progresses and ends up being out of sync over the duration of the finished product.
Is there any advice anybody could give as to how to fix the problem? I'm sure it would be a simple fix for anybody with experience of this type of thing.
I am running it on Windows 10 platform. Hope this helps.
Thanks in advance.
Bolosun
I use ffmpeg to capture the video from my VHS tapes. I tried the Arcsoft s/w and the lag was dreadful. No issues use ffmpeg.
LV426
Administrator
Staff member
If the audio lag is constant throughout (i.e. doesn't "drift" one way or the other) then it's quickly and easily (ish) fixed by using a free app called tsMuxeR.
Given that presumably you have already captured some or all of your tapes realtime, recapturing them using another app will take the same length of time I guess. Fixing what you already have may be quicker.
One file at a time:
1: Watch video and estimate how much and in which direction the audio is "off" - early or late?
2: Add file to tsMuxeR (which should show a video and audio stream).
3: Highlight the audio stream and apply an audio delay. Negative number if the audio runs late (behind the image); positive number if it runs early. Measured in 1000ths of a second (millisconds).
4: Remux it to .ts or .m2ts. This typically takes only a few seconds - but you will need disc space for the extra file created. It's not re-encoded; just split and rejoined.
5: Watch the NEW video and estimate how much and in which direction the audio is "off" - early or late?
Go to 1 (with the original file) if necessary and repeat with an adjusted delay value - trial and error - till you get it right.
The more you do, the better you get at that initial estimate. It may be that your capture app is predictable and they are all the same (in which case items 2+ will be one attempt only); or not.
Hitachi163
One file at a time:
Hi, thanks very much for the advice. I'll double check if I have a constant lag or drifting...If its constant, I'll give your method a try. Thanks again, it's appreciated.
raymondo44
One file at a time:
19th January 2022
Hi, like others, I have used Arsoft Showbiz for some years and I've always had the audio sync problem.
The speech is slightly ahead of the video and it's very interesting to read your article on using ts<ixeR and I have tried using it but so far not happening.
I tried using tsMuxeR with an Acrsoft Showbiz recording (MPEG 2) but it doesn't accept the file.
Can you please guide me on using the tsMuxeR and I apologise for my lack of knowledge
I would be very grateful for you help!
Ray
LV426
Administrator
Staff member
Not without more info and possibly not even then
"It doesn't accept the file".
Why not? Where does it fail? What is the file type/extension? etc.
