Chadford
...well not me I'm trying to help a friend.
Here's the scenario.
My friend's a composer and performs contemporary music concerts. To accompany his music he also displays a video sequence (~1 hour long) using a laptop plugged into a projector.
He uses a modified version of Fractint running on a really old IMB laptop (Win95).
The problem is...
1) He is worried that this old laptop will die at some point soon.
2) He has lost contact with the guy that modified Fractint.
3) He does not have the source code for the modified Fractint.
4) The modified Fractint runs too fast on a modern laptop.
He would be happy to somehow get a DVD of the of the sequence and use the DVD instead.
The output he uses is from a standard VGA output - I think the resolution is 800 x 600.
He has tried a cheap VGA to composite converter (~£20 from Maplin) to try and record to DVD, this does not work well.
I have considered using a modern laptop with his Fractint and running CPU crippling utility but I don't think this work as part of the sequence runs correctly on a modern laptop but some of it does not (too fast).
I think the solution is to use some form of capture unit.
Can anyone suggest something that has a chance of working?
...also can anyone suggest where else I can post this request for help?
Thanks.
Edit: 'Fractint' is a very old program that displays fractal images that can morph from one into another. His modified version allows secondary images to blend in an out using varying transparency and colour transitions linked to the fractal being displayed
The problem is...
Thanks.
