Video Camera upgrade
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Aitch, May 5, 2003.
  1. Aitch
    Aitch
    May 5, 2003
    22
    West Glamorgan
    I have just sold my Sony tRV46 Hi 8, and am now looking for a Digital replacement. I have some old Hi8 tapes so it would have to be backwards compatible. Whilst i have a brand loyalty to Sony, I was wondering are there any other makes I should have a look at. My budget is £550-600, and I already have the editing software etc on my computer so it will be a long term purchase. Any help or ideas much appreciated, regards Aitch
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Well SOny are the only D8 manufacturers so you will have to get a Sony
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Martin is right, If you want to play back your old Hi8 tapes you have to get a Sony Digital 8 camcorder.
    No one else makes Digital 8.
    Beware, some of the cheaper Digital 8 camcorders dont support Hi8.
    So ask before you buy.
    Good Luck
  4. Aitch
    Aitch
    May 5, 2003
    22
    West Glamorgan
    Thanks for your help guys. I can now start to play with the plastic.
    Regards, Aitch
