chedmaster
- Joined
- Jan 29, 2005
- Messages
- 2,661
- Reaction score
- 28
- Points
- 435
- Age
- 35
Both screens are said to be HDTV compatible on the ebuyer website. I prefer the H+B and although i know little about it at the moment, the reviews on ebuyer seem good. It also has two component inputs, and detatchable speakers (and looks nicer). The DVI input says HDCP compatible, with a simple HDMI > DVI cable will this be fully HD compatible? I was sure of it until some monkey on ebuyer "warned" everyone it does not meet the specs to be "HD ready".
If this is the case would it be the same with the Video7?
Finally, as there is just one DVI input, will there be, in the future, adapters that allow the connection of, 2 or 3 for example, DVI plugs to one input? (like for scart atm) will they still be HDCP compatible etc.
for reference both screens say compatible with 480i/p, 720p and 1080i
thank you all for your time, all i want is a big flat screen on a budget - its so hard!
