Vice City - limited sound effects
Discussion in 'PC Gaming & Rigs' started by Gordon A, May 16, 2003.
  1. Gordon A
    Gordon A
    Mar 23, 2002
    145
    +37
    Received this today from Gameplay (thanks for the great service) and it looks brilliant. The only thing is that some of the sound effects are missing! By 'some' I mean, for example, the noise of the car engines, gunshots, footsteps etc. Tried taking the background music to 0 and increasing the SFX level but nothing: total silence! The music and voices etc. are OK. Running onboard sound on an Asus A7N8X deluxe mobo but have got no problems with anything else. Any ideas appreciated!!
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    2
    Aldershot, Hampshire
    +267
    What amp/speakers are you playing the sound source through?
  3. Gordon A
    Gordon A
    Mar 23, 2002
    145
    +37
    The speaker setup is Creative's 5300 system. As an extra to my original post, you can hear the general background effects: it's as though the foreground effects are missing in some way! Difficult to describe sounds in writing!!
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    2
    +267
    Go to sound and audio devices in your control panel. Click on the audio tab and advanced button on sound playback (i'm assuming your running XP). Make sure it's set to 5.1. What sound card is it your using? Make sure all your speakers are working in 5.1 mode - most cards have a test for this to make sure it's working ok. Other than that check for patches to see if this will correct your sound issues.
    What version of direct x have you?
    Have you up to date sound card drivers?
  5. Gordon A
    Gordon A
    Mar 23, 2002
    145
    +37
    Thanks for the help. Sussed it out this afternoon when I found that my playback and record devices buried within the nForce control panel were set to 'Playback through TotalRecorder' instead of NVIDIA nForce audio. Somehow, the auto detect on Vice City must've altered the settings!! All now works a treat.
  6. gyates93
    gyates93
    I have the same problem, but i've tried what you said and it makes no difference. If it helps, I'm on a toshiba satellite laptop. I don't have the problem with any other games except this one. I'm running windows XP media center edition. Sorry for bringing back an old thread but I found it on Google Search and i'm new to this forum.
  7. gyates93
    gyates93
    Well I have to say, you are all very helpful... :mad:
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Have you tried re-installing Direct X? Could be your missing one of the sub-components?
  9. gyates93
    gyates93
    Well there's no problem with any other games that use directx, so I doubt that's the problem. I'll try anyway though.
  10. gyates93
    gyates93
    I went to the directx website, downloaded and installed their latest version. Still no difference:(
  11. Marc
    Marc
    Jul 8, 2004
    11,610
    Portsmouth
    +1,081
    have you got any codec packs installed, ie k-lite codec pack? Quite often these mess up the sound in games due to using non certified or hacked codecs which are not supported by the game. If this is the case and you need codecs installed, you can either rearrange the priority of the codecs in 'control panel/sounds and audio devices/hardware/audio codecs' until you find one that works, or you can install the codec package called "FFDSHOW" instead of all your audio and video codecs and add any games with problems to the exclusion list in the FFDSHOW configuration
    and there's no need to be rude, you probably would have had a better response starting your own thread rather than bumping one that's nearly 4 years old!!
  12. gyates93
    gyates93
    I tried that, still no difference.
  13. gyates93
    gyates93
    Well I found the problem. My sound card does not suppord hardware buffering. Is there any way to get all of the sounds out of the game without hardware buffering?
