Vibrapod
Discussion in 'Arcam Owners' Forum' started by Sweden, Jul 20, 2005.
Tags:
  1. Sweden
    Sweden
    Hi ,
    Is someone using them on their Cd/dvd players ? Good ?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    No, I use Nordost Pulsar Points and also Stands Unique Carbon Isolators, both work very well.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    seem to work well :)
  4. Timmy C
    Timmy C
    Oct 10, 2003
    5,181
    +398
    Do you just sit your cd /dvd player on these Pulsar Points or do you somehow attach them to the casing? Did you remove the original feet from your Arcam kit or do the Pulsar Points go underneath them? If they sit under the original feet then doesn't that make the kit stand a bit high?
    The reason I ask is that I've got some but have never been quite sure of the best way to use them!
  5. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    I've got pulsar points under most of my kit. This includes my speakers instead of the 8mm spikes and they work very well. You get them pre drilled and treaded6, 8mm etc. With the lighter kit like my CD player and preamp I just put them as close to the original feet as possible and I've had no problems.
  6. OneDesi
    OneDesi
    Mar 10, 2005
    8,513
    Black Country
    +255
    Hi I use these under my Musica lFIdleity Xray V3 and X150 and X10V3 and I think the impact was great. What surprised me was that they improved the sound when placed under the X150 but not so much under the X10.
    For the money, well worth it and are more discrete than oak cones!
  7. Timmy C
    Timmy C
    Oct 10, 2003
    5,181
    +398
    So in the case of your cd player and pre amp you remove threaded bit and just sit it on top of the small bit of the Pulsar Point that it turn sits in the big bit. Is that right? Sorry if this question seems daft but I've got no instructions or anything and don't know quite how they work!
    I've got the same cd player and pre amp as you so I think I'll give it a go.
  8. Sweden
    Sweden
    i use a soundstyle furniture w glasshelters so i guess i cant use pulsar point ?
    btw its very easy to take off the original feet , just take them off !
  9. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I sit the small section of the pulsar points on top of the larger section so they are balancing on a very small contact point. I then place each of these under each foot of my cd player. It does make it sit a bit high but as my cd player is on the top shelf it does not matter. Here are some example pics
  10. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
