vibe delta box
Discussion in 'Video Streaming Boxes & Services' started by shady786, Mar 26, 2006.
  1. shady786
    shady786
    hi every one
    im connecting my vibe delta box line driver check it out at http://www.vibeaudio.co.uk/index.asp...ssories-f.html does any one know were should i put it?
    will it be better off just next to the head unit or can i bring it to the boot next to the amp? will it reduce the quality of the sound if i take it to the boot cz of the rca cable traveling through the car then getting boosted or is that wrong, some one plz correct me :suicide:
  2. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    Hi Shady welcome to the forum. It will not really make a diferance where it is. Subject to clearance behind the headunit. If you are going o fit it make sure you ground is good ( earth) and all the connections are made and job should be a gud un.
  3. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    If you are fitting a line driver what you really need to know:
    Is the amp up to the job ie canm it handle the volts you are about to "input"
    Please confirm list of equipment thanks.
  4. shady786
    shady786
    i have a fusion fjl 1211d i think it shuld handle it, i thought the signal might get abit interfeared if i put the line driver at the boot because of the rca cable traveling through the car first then into the the line driver thanks for your advice
  5. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    Dynamic Power 2500 Watts
    Damping Factor > 200
    T.H.D. 0.05%
    Dimensons (mm) (W) 275 x (L) 365 x (H) 65
    Variable Phase Shift 0 – 180 degrees
    Variable Sub Sonic Filter 10Hz * 35Hz
    Variable ŒQ
    Variable Input Adjustment 200mV * 7VRCA Input and Pass Thru
    Chrome Anti-tamper Cover
    5-way protection: Thermal, Overload, DC-Offset, Short Circuit and Reverse Polarity
    12.6 Volt Power Output Specification
    – 600 WRMS x 1 into 4 Ohms
    – 850 WRMS x 1 into 2 Ohms
    14.4 Volt Power Output Specification
    – 800 WRMS x 1 into 4 Ohms
    – 1250 WRMS x 1 into 2 Ohms
    Seems to be able to manage it. What headunit are you using?
    Also i as a rule run my power cables one side of the vehicle and the signal the other. Also it does not matter where you wire it in. I would put it as close to the amp as possible.
  6. shady786
    shady786
    thanks thats really helped theres one more thing in my head that ive been asking every one, is there any point in having a 0 gauge power cable then turning it into a 4 gauge using a fused distribution block or is pointless and the same as having a 4 gauge wire from the battery instead :lease:
  7. shady786
    shady786
    im using a sony 3 equalizer xplod head unit because got it really cheap want to get the new alpine headunits but broke at the moment, have you got an install that ur proud of??
  8. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    in short,
    the power you are gonna use needs to come from the battery. the more you need the better #( thicker) the cable has to be. as the run from the block is short its ok to use 4 awg. but from the battery use thicker thus avoiding fires/shorts and car burnouts. :thumbsup: :cool:
  9. shady786
    shady786
    thanks alot m8 for all the advice :smashin:
