Vibe Alpha 1 sub
Discussion in 'Subwoofers' started by MarkEmmett, May 23, 2002.
  1. MarkEmmett
    MarkEmmett
    Hi there everybody I am new to this forum and would like to know weather anybody has heard the Alpha 1 and what they thought of it . I am currently putting a HC system together and have not yet decidded what sub to buy . The fronts are b&w 603 s2,lcr6 center And kef uni q rears And a Marantz sr5200 amp.
  2. Bonesy
    Bonesy
    Feb 22, 2002
    1,170
    Wiltshire
    +37
    I bought a 2nd hand vibe beta at xmas.
    it is big, and heavy.
    seems well built.
    as for the sound. I've not really been able to get it set up right . sometimes comes across a bit boomy.
    The latest place I have it seems fine though, so will play with avia to get it right.
    if you can get it fairly cheap, ie cheaper than a rel, give it a go. spend a week setting it up, and then return it if you still can't get on with it.
    in my view, they are a well built, interesting and powerful alternative to the rels of this world.
  3. Bonesy
    Bonesy
    Feb 22, 2002
    1,170
    Wiltshire
    +37
    actually, a cheap rel 150 would be a good choice.
    but I suggest that vibe might be better than a B&W or kef alternative sub.
  4. Brox
    Brox
    Oct 26, 2000
    313
    16
    Marlow, Bucks, UK
    The new vibe alpha costs £300 and is in a small cabinet around a foot high and wide, this was reveived recently by What hifi (maybe the latest issue or the last on) and was given 2 stars.
    The older vibe alpha now called the vibe alpha 2 is reviewed on this site.
    Hope this helps
