VHS to SVCD or DVD via PC
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Dave Taylor, Dec 29, 2003.
  1. Dave Taylor
    Dave Taylor
    Oct 7, 2001
    274
    High Wycombe, Bucks
    +15
    What is the best / low cost solution to get some of my old VHS programmes onto my PC so I can then burn them onto a SVCD or DVD.
    There is a Video to USB box D ? 10, do they work or is a PCI card better.
    I once had an external sound card that was USB and I used to get audio drop out.
    Dont want that with video
    Regards
    Dave
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,107
    Rainham Essex
    +2,380
    Getting analogue video onto a PC took very expensive equipment until the recent release of USB2.0
    If you have USB2.0 (if not then get a USB2.0 PCI card for about £15) then there are several makers of analogue capture devices that connect to it. These cost around £40-£50 from e-tailers such as Dabs etc and are made by Dazzle, Pinacle, Belkin etc. They should be supplied with basic software and tend to work very well.
    To prevent drop-outs with these devices (and any video editing) you should stop ALL background programmes such as anti-virus etc. You will be surprised at just how many un-needed progs are running. A good way to stop all these is a free download prog called EndItAll (do a Google search).
    Mark.
