VHS To Panasonic DMR-EX75
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kevosull, Feb 11, 2009.
  1. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    Hi all,
    I have a requirement very soon to copy some home made VHS recordings to DVD.
    I think I'm correct in assuming the HDD-DVDR I have has a TBC built-in, but wondered what connections it works through ?
    Scart? S-Vhs ?
    My Vcr only has a scart out, so that's a no-brainer, but would like to know whether I need a scart at the HDD-DVDR end, or one of those converters to phono & S-vhs.
    On a connected note, any pointers to easy to grasp PC based editing software would also be really appreciated. :smashin:
    Thanks in advance for all and any assistance.
    Best regards,
    Kev
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,154
    +7,095
    Hi Kev.
    The connection is not critical. You can connect to AV2 AV3 or AV4.
    So a simple scart link is probably best.
    There is no point in having a scart to S video converting lead because you unit will not output S video unless it is a S-Video machine - which I gather it is not - so it would not work at all.
    I've no recommendations for software.
    You may actually find it better to edit on the machine HDD before you burn discs from the transferred material.
  3. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    Hi Gavtech,
    It's been a while, hope you're ok :hiya:
    Thanks for the clarification, scart it will be, although I do hate having to remove the cable from the back each time.
    So because the Vcr is not an s-vhs model (you're correct), then whatever method of connection, I'm only sending a composite signal ?
    If so, then a scart to phono converter into AV3 (front) would be the same quality of signal, and save me messing around at the back ?
    But the Panny should TBC the signal so the audio/video stay's sync'ed? :rolleyes:
    Thanks again :smashin:
    Kev
  4. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    (gonna be in trouble now) :nono:
    Any takers :lease:
    Thanks,
    Kev
  5. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,154
    +7,095
    Hi Kev.
    Sorry I missed this.
    Yes use the front connection by all means. Quality will be the same.
  6. Kevosull
    Kevosull
    Sep 1, 2006
    107
    +5
    Hi Gavtech,
    Much obliged :thumbsup:
    Best regards,
    Kev
