vhs record non16:9 from widescreen dvd what do you get?
Discussion in 'Digital TV & Video Players & Recorders' started by tfraser, Nov 16, 2001.
Tags:
  1. tfraser
    tfraser
    Has anyone tried to tape from a widescreen dvd onto vhs?
    What results in format did you get?
    Did it work at all?
    Thanks for any feedback.
  2. Duncan Harvey
    Duncan Harvey
    Unless I'm missing something, you simply get a VHS copy of what you're watching - ie anamorphic DVD recorded onto tape.
    If the disc isnt protected, then anamorphic recordings onto DVHS look superb.
  3. tfraser
    tfraser
    I was wondering if the recorded format to tape is the 4:3 part of the widescreen i.e. you would miss a bit at each edge?
    or does it record exactly as appears on the tv screen?
  4. Duncan Harvey
    Duncan Harvey
    when you play back, on a 16:9 set it fills the screen, and on a 4:3 it looks squashed, unless you have a 16:9 mode.
    ie just like playing back an anamorphic dvd on a player informed that the tv is 16:9
  5. Kevo
    Kevo
    Aug 23, 2001
    5,354
    Manchester
    +144
    4:3 or 16:9, the picture resolution is the same.
    It's all in the shape of the pixels and the digital squeezing and unsqueezing.
    Somebody else will probably be able to give a more technical explaination.
