vhs copyright protected???????
Discussion in 'Digital TV & Video Players & Recorders' started by whatthecrap, Jan 15, 2004.
Tags:
  1. whatthecrap
    whatthecrap
    is it possible for a vhs to be copyrighted to a point where when trying to capture it on a computer, that it wouldn't be allowed? if so, how would you get around it? if not, what other problem would this be?
    thanks
    What_The_Crap
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Was Macrovision implemented on VHS tapes, or only DVDs? That's an analog copy-protection system.
  3. pr1uk
    pr1uk
    yes macrovision was/is used on VCR tapes and in the bad old days when i used a VCR i had a 'bug master / bug basher' that sat inline and took the protection out.
  4. whatthecrap
    whatthecrap
    is there any way to physically remove the protection? kind of like audio cassette tapes, where you can put a piece of tape over the hole so you can record over them?
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
  6. Azrikam
    Azrikam
    I've also heard that if you use a long enough scart cable, Macrovision doesn't work. Haven't tried this out, though, so it could be baloney.
  7. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    you can do the same with vhs as audio tapes on the left hand side as you look at the tape with the flap facing away from you there will be a square hole that can be taped over.
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Copying to a Beta deck works as well - Beta removes Macrovision
  9. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,842
    Somewhere in South Yorkshire
    +5,077
    Beta doesn't remove Macrovision. It isnt affected by it, but, if you subsequently try to copy off the Beta tape, you'll find that the Macrovision is still there on the copy.
    It's an interesting topic. My video capture card (an old Matrox Rainbow Runner) makes perfectly good 'grabs' of sources (VHS or DVD) with Macrovsion. Unlike Betamax it actually DOES strip Macrovision out of the signal.
  10. whatthecrap
    whatthecrap
    thanks, i'll try that.
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    It isn't - when Beta is recording as soon as it can get a good sync pulse it continues to generate its own.
    Tested by copying DVD to Beta and Vhs
    Beta fine
    Vhs grotty
    Then Beta to Vhs and Vhs copy as fine as Vhs can be.
    Also copied a few pre rec Vhs tapes to Beta to sell them off while waiting for the DVDs to come out
  12. LV426
    LV426
    Jul 14, 2000
    12,842
    +5,077
    Well, all I can say, is that that isn't the experience I had with a Macrovision VHS > Beta > VHS copy. The Beta copy played fine. The 3rd generation VHS copy had all the hallmarks of Macrovision.
